Picked up my second hand vehicle from a local dealer last week. First trip out today where the car was misted up. So I put on the front and back heated screens which worked great at the front, however there are around 10 element sections in a row that are not working. leaving a small section top and bottom which are (so not ideal)
Anyone have any idea how easy this is to fix? or replace? if not I will give the place a bought it from a call, which I probably will anyway. I've seen some paint stuff you can put on if there are breaks, but until the weather cheers up and I get some good light I won't be able to tell.
Cheers for any advice, I should also mention it's still under manufacturers warranty but I can't imagine they would replace / repair it under that? (Ford)
