Reboot and select proper boot device error
11 Jan 2011
Hi
So today I've been updating drivers and the BIOS for my motherboard.
Everything was fine and it restarted several times without a problem.
Then of course on another restart I get the error "reboot and select proper boot device".
I cannot go into the BIOS and the keyboard and mouse don't work.
I literally cannot do anything, it starts up and then goes straight into that error.
I have no idea what to do and I'm confused as to why it decided to do this after several restarts.
I am in desperate need of some assistance to fix this problem!
Thank you
How many hard disks do you have? Try unplugging all but the one the OS is installed on.
I disconnected the blu ray drive and it boots fine, but whenever I connect the drive up it comes up with the error.
I've gone into the BIOS and the SSD is #1 and the secondary HDD is #2 as boot order so nothing changed there so I have no idea why this is happening.
I might go back to the old BIOS if it continues.
Are you windows 10 and controlling all driver updates, or did a driver get updated behind your back ?
If the blu-ray drive , kbd & mouse are all on usb does that driver have an issue - thought there was an issue with win10 using wrong usb3 drivers
Windows 10 is great huh? It has been a year, seems the issues should be fixed & I hate how it downloads even drivers behind your back... My net wouldn't work, seemed nothing worked, it would just randomly disco & I got DNS client Event in event viewer... I just put Windows 7 on again, getting tired of 10, found Windows 10 suddenly killing internet connectivity for some users, so that sounds fun...
