Rebuild and some new Kit
15 Feb 2006
Staffordshire
Finished at the weekend:
Installed:
Aquacomputer Aquero
GTX 480 Nickel Plexi Block & Back Plate by EK
Rampage II extreme Full cover Nickel Plexi block by EK
Rampage II extreme Mosfet/ VRM blocks by EK
Bitspower fittings
Fluid XP Extreme blue
Very impressed with the Aquero. Tricky to set up at first, but thats only because there are so many settings and options, and so much it can do.
Finished spec:
intel 970 Gulftown @ 4.2GHz
Rampage II Extreme
6GB Corsair Dominator GT 2000 C7 (20,7,8,7 1T 2005MHz)
GTX 480
Corsair F60 SSD
Veloci 150GB X 2 (stripe)
Enermax Revolution 1050W
X-Fi Fatality
800d
The blocks were quite tricky to fit (particularly the GTX 480 block), but i think it was worth the effort.
Next job is SSD next weekend :)
Few more pics below and also some of the GTX with new thermal pads applied ready for the block.
