Permabanned
- 22 Feb 2010
Hey there
As we all know im useless at building computers and then keeping them for more then a week without haveing a fiddle.
Also that i cant make a real project log as i work quickly.
This build contains these parts:
Intel I7 950
Gigabyte GA-X58A-UD5
6GB g.skill 2000mhz.
XFX XXX ATI 5970
2x 1TB F3's
1x troqx 128GB SSD
and some DVD drives.
Cooling:
PA120.3 + Shroud
XSPC 120.1 Thick
EK mutli 150mm
DDC 18W with an old clear top.
EK nickel 5970
black 5970 back plate
EK HF Supreme for the CPU
Blue UV tubeing
mixture of COmpressions and normal barbs
All in a Black external and internal TJ07
Will let the pictures talk.
These are the two new parts i wish to add to my rig, To do this it has to be stripped down
I need a place for this new rad, So This seems like a good place?
Will sit there
Plonked it in
its strapped in at the top as it was impossible to use screws!
A kinda bare view
Put the shroud on the rad
Stopped to make a snow mound !
Plumbed it all in with new pump top.
Decided i like the look of my SSD. So its on show!
To many wires!!!! So cut some off
No then this is where i had a major issue!
The new pump top had a large leak, a VERY large one, the outlet had cracked and joined with the screw thread = water all over the place and inside the pump...
The pump ended up fried and the Top useless.
SOoo Its a good thing i have 4 pumps! So in goes a spare 18W ddc with an old top i had laying about
Resused my EK mutli res
Now for the end shots (useing my HTC Desire HD)
had to buy a new chair for xmass aswell.
One last problem.
I have no idea where to mount my 2x 1TB drives... They wot fit down below or in the middle, or in the drive bays as they will look a mess.
I think i will need to make some sort of place for them at the top so i cant actually see them.
Please let me know what you think and if i can change anything.
Things to do:
Braid the second PCI-E wire.
Wire up DVD drives with new Sata wire im makeing.(short)
Make a HDD place.
Intel I7 950
XFX XXX ATI 5970
2x 1TB F3's
1x troqx 128GB SSD
Cooling:
PA120.3 + Shroud
XSPC 120.1 Thick
EK mutli 150mm
EK nickel 5970
Blue UV tubeing
Will sit there
Plonked it in
A kinda bare view
One last problem.
Things to do:
Make a HDD place.
