Rebuilding a cube pc . . .
17 Jun 2006
I am transforming an old Cube/Shuttle PC that we have in our shop from Pentium to Core 2 - my question is . . .
What PSU should I buy from OC that will fit in the Cube/Shuttle???
E6850 and ASUS MB + 2 x HDD's etc etc
khushy
What's the current PSUs specs? It might just handle, since C2D consumes less.
Hope the Asus mobo will fit especially if case is Shuttle make.
If it is a proper Shuttle then you are best looking to them for a new PSU as it seems OcUK have stopped stocking Shuttles again.
If it is a generic cube type PC then perhaps the Enermax 285w mATX PSU will do but it is only a guess since I don't know the measurements.
aha . . .
2 good points - I will dismantle it and check the dimensions before ordering anything and I will also post up the make of the current PSU!
khushy
