Managed to pick up a Corsair 800D from the MM (thanks Bailey). Time to ditch my 500R and get some real room!
While moving everything over I intend to change out the tubing and cable extensions, get everything looking a little better
Thinking of going for blue, should then match my chipset heatsinks (asus p8z68), ram and raystorm LED's. My question is what tubing do you guys think would suit the best? been looking at the Masterkleer UV Reactive Blue but can't make out if it would appear more of a purple?
Also I plan to bolt my 1080 rad to the side panel of the case while still using a large external res, due to the location of the WC grommets on the rear I was debating putting the GPU's into parallel, as the in and out could the run from the top card, would this make any drastic effect on temps (currently around 21c idle 36c load)?
Really looking forward to using the case, though I'm not going to rush into it this time
