reCaptcha Woes
2 Oct 2019
Castle Cary
These damn things drive me insane - just been stuck in a seemingly endless loop. Got so peed off I just went to another site.
My question is - when yoy get a prompt that says something like select all squares with traffic lights, do you just select the squares with the actual lights or do you select that squares that also contain the structure that supports the lights?
Similarly, when it says select all squares with bicycles and there is one bicycle, so you also select the squares into which a tiny bit of the cycle overlaps and do you select the squares showing the rider?
I could go on....
Yeah those ones are irritating
You can use browser extensions to solve
Some of them
But they dont solve 100% of them
As they constantly evolve
