Reccomend a Headset with Mic
25 Dec 2012
Hello,
Can anyone Recommend a headset that will be mainly used for Gaming.
Budget is about the 50-60 Mark
Must have Big Ear Cups
Wired is Preferred
Thanks
I have a Turtle Beach Ear Force P11.
It fits PC, Xbox and PS3.
No doubt there's better out there but I think it's good for the money.
I use these:
http://www.overclockers.co.uk/showproduct.php?prodid=SP-021-ST&tool=3
They are normally£59.99 but there on a deal at the mo for £49.99
They a steelsseries Siberia v2 they are really comfy lightweight and the sound reproduction is good and the mic pushes back into the head set and u can use them as a normal set of headphones as they plug into iPhones,iPods and so on.
But check as I did see that there was a apple set aswell and don't know the difference between the two but they where still £60
