Reccomend me a card reader.
Caporegime
12 Mar 2004
England
Only needs to support the most common formats, sd, cf, ms, must have usb 2.0 connectivity. Can be external or internal.
just get the cheapest one you can find in your local shop, there's not much difference between one and another i'm sure.
Thats what I thought until I bought a cheap one which was thrown in the bin the next day due to the card jamming in the slot and the computer not recognising it properly!
uhm... take it back?
just go with a brand that you've heard of and i'm sure you'll be fine
