Reccomend me a codec pack
30 Aug 2003
Straya
Just did a fresh install (sigh) and forgot the uber codec pack I had previously installed on my PC.
Can anyone reccomend me the one?
Thanks
http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm
http://www.cccp-project.net/
http://www.cole2k.net/
I don't use any codec packs because I use VLC. The three links are just the ones I know of. If I were to choose any codec pack I would go for the CCCP, I've read about it on the Internet and it seems to have the right idea in giving you the codecs you'll most likely need and in a fashion that you can get rid of them easily. The K-Lite and Cole2K.net codecs I've never used and so can't vouch for them, but it doesn't seem as if you want recommendations but just help in finding the one you used to use.
K-Lite is very good, but you could always go for VLC player - that way you don't need to install a load of codecs and possible mess things up, you'd just have VLC which plays anything.
G|mp said:
Ive only ever had the K-Lite one, never needed another plays everything you throw at it
K-lite when i last used it a year or so ago, had all kinds of incompatible codecs - certain films would show up green etc etc.
Forget dloading codecs and dload VLC - job done.
I am starting to really like VLC b ut currently use Medi Player Classic (Real/Quicktime Alternative) and that has played everything I have thrown at it as well.
One question for thge VLC fanboys, is there a way of displaying the progress bar of a video on the screen, if I use full screen on playback I can find no way of seeing the progress etc. In MPC moving the mouse to the bottom of the screen reveals the progress bar, something similar in VLC would finally win me over?
Don't think so. Not really sure. I never really play fullscreen :|
MPC is also the only player that will play sub files with a dvd :D
bit of a hi-jack but this is really ******* me off.
I have VLC and have installed more codecs than you can shake a big stick at but i still get random videos which come up in grey ????? no picture just a grey screen and sound ??? Ideas ?? :confused:
yes, get GSPOT codec information program thing
http://www.headbands.com/gspot/
find one of the files that plays in grey / wierd sound
open it with gspot, tell us what it says
PS if you are getting this in VLC then you might wanna try uninstall all those crappy codecs 9/10 times its incompatability between them
got gspot.
The one video i have on my pc at the moment that does it coems up as a non valid avi file :S
Mostly though its videos on the internet like E3 trailers (the new crysis one :mad: )
give me the link to one of the files u have a problem with
there is another prog i use but i cant find it atm so i cant link you to it :\
Firefox. the thing is i get it if i actually DL the video with "download embedded" and try and play it in vlc or media player it still does it :confused:
I thought it was my pc but i just got a new rig and it still does it :S
ff is random with playing videos, i dont know they wrok fine for mine inbed into ff, but id sugest getting something like quicktime light (something like that for firefox.)
{vlc should work with ff too theres an option on install for ff plugins }
those files are .wmv
http://media1.break.com/dnet/media/content/wingless1.wmv
Does it not open, when u've dlaoded them on ** pc, in windows media?
