ATM i have BT infinity with a homehub 5 i think it is, this is at one end of the house where the phone line is located, and serves that end of the house with wifi.
The wifi dosent make it to my bedroom, so i ran a 30 meter lan cable from the main homehub, and used an old homehub 3 in my bedroom.
i followed some guide on the net that turned it into a separate network 9something with turning off DHCP or something)
But it works, i have a separate network linked to the main bt hub, but its getting slower and slower.
So i think its time to replace the router in the bedroom. but what with?
ideally i'd like one with 5 lan ports, as i have 4 items that i want wired connections to, but only 3 ports are available with my current set up after using one to link to the homehub 5.
Would also like a decent wifi connection, this one keeps dropping out all the time, and will be getting a new laptop soon with that wifi 6 stuff in it, so not sure if i can match up something that will work it's best for the wifi side of things, (you can tell i'm out of my depth here can't you)
i just really watch youtube, download occasional games off steam etc, i dont play any online gaming, so i dont need something ultra fast, but i want something where it's at least faster than my phones 4G speeds when in hotspot mode as it is now.
budget, around £50 if possible,
