Reccommend a Joystick for X3
18 Oct 2002
Cambs
Just started playing X3 and reckon I could do with a joystick.
Fairly sure I played X2 with a joystick but it was so long ago I can't recall.
Bearing in mind I'll probably never use it for anything else, I only need a cheapy I think.
Any thought?
I'd go for a Microsoft Sidewinder Force Feedback Professional 1 and a gameport to usb adaptor if you can find one. Great sticks and can be had really cheap second hand ~ £15 including the adaptor.
If you've got an old rig then you might be able to leave out the adaptor. :)
LoadsaMoney said:
One of these should do the trick. :)
Cracking sticks. :D
Quoted for truth and all that.
I've got a very old Cyborg 3d Digital stick from Saitek and I have to say that in my experience they make the best pc joysticks/pads.
Of course, console pads/sticks with converters can often be even better :) Probably not in this case, though.
