HI, I recently overclocked my pc but now when i startup the RAM Wont light up, wait 10 seconds and the lights come on but it does nothing. I hit the restart button and then the pc works fine?
I havnt changed the ram setting's at all just the HT and CPU from 2Ghz to 2.5Ghz and upped the voltage a bit. I was thinking the voltage of the Ram may need increasing, but i looked at the options and it's not there. It's in my manual for the motherboard and gives me the option to change the ram voltage but its not there when i look? or could it be the timing's of the ram that need changing?
I currently have (2x1GB) of Crucial Ballistix Tracers 939 Dual LED
3.0-3-3-8 with 1T/2T set as 2T
The Ram has changed now the cpu is at 2.5 the ram is at 500MHZ (250) which i believe is its max do you think the following setting would cure this?
2.5-3-3-8 with 1T < I have AMDx2
