My new project is to build a silent machine - if this is at all possible!
So what do I need guys?
- SSD
- Passive CPU Heatsink
- Graphics Card with Passive Cooler
- PSU with a fan that only starts up under load?
- Decent case
Spec is what I can re-use. I should be able to use my P182, maybe replace fans with quieter ones? I guess whatever you build, you need some airflow. I don't know how noisy my PSU or case fans are alone....I should try check.
I'm looking to build an i5 or i7.
So what do you think guys? Laptops are silent, iPads are silent... why can't we do the same with PCs? Has any forum member here built a silent PC yet?
- SSD
- Decent case
