Permabanned
- 23 Nov 2019
- Scotland
I just found out that the Lian-Li 011 case does not allow the Noctua NH-U9S to fit. I either have to find another case, or change the cpu cooler. Should I look at a Noctua top flow cooler or find another brand?
Does anyone recognise this cooler?
What motherboard and RAM do you have? If it will fit your mobo and you get a case with 171mm or more CPU clearance you could fit TRUE Spirit 140 Power in, one of the very best coolers and only a few quid more than H7.
Lian-Li make quality cases but they are not much good for air cooling because their venting is more for radiators than through case airflow. If you could return / exchange case for something else with better airflow and more CPU clearance I would. But it's your choice.
