recomend a cpu cooler and vga cooler?
4 Sep 2005
Lowestoft
needing something for a 8800gt + a E6600
Must fit on a asus p5n-e sli board and in a Thermaltake VB1000SWS Soprano
Thanks!!!
Money dont matter but really want good price for the overclock limit
Remember to buy some thermal tape for applying the RAM sinks for your accelero.
also which tape?
can u give me links to Thermalright Ultra 120 with a 120mm Yate Loon fan plz
You just buy a thermalright 120 ultra extreme, then you buy the fan, they are seperate items. You buy the fan because the heatsink doesn't come with one included.
As for the tape, any I think, you need it because the stuff that comes with the cooler isn't very good.
As for the fans, it depends on how good your case airflow is/ if you want the card to be passive or not.
to use this : http://www.overclockers.co.uk/showproduct.php?prodid=HS-032-ZA&tool=3
would i need anything else extra?
my 8800gt shut off yesterday and made a pop sound which was the fan and now its making a noise as its its catching around the rim of the fan shell. have contacted xfx for an rma but if there only gonna send me out the same card with a new fan or a new card the same then i may aswell u save postage money and buy something which will fix my problems.
also is either of these worth a go with the zalman fitted:
http://www.overclockers.co.uk/showp...7&subcat=399&name=Akasa System Exhaust Blower
http://www.overclockers.co.uk/showp...at=399&name=Antec VCool Expansion Slot Cooler
also will this Thermalright Ultra 120 with a 120mm Yate Loon fan fit in:
Thanks! Really wanna order asap to recieve before the weekend! thanks
sry and one last thing where does the fan i add to the Thermalright Ultra 120 plug in to? "cpu fan same as any other"?
also which out of the 3 yates fans is best? thanks
