Recomend a good CPU waterblock block for AMD Ryzen
I think rest of them have similar performance to each other, so it's just up to the looks. Which one you prefer.
I am leaning towards the EK velocity nickel block, seems to be low restriction which is always good imo.
Hazel, the performance of most of these blocks seems to be within 2c of each other, although this is with Intel cpus. I can't seem to find a round up done on Ryzen.
Yeah that's the issue with reviews...only Intel. I think however it will be the same, because none of those cheaper blocks (<£100) were specifically designed for Ryzen dies.
Only magnitude is special but again, the only review I saw was on guru3d. EK claims it's the best for AMD and the more cores the bigger benefit...but also price.
I myself bought a Optimus Foundation took 3 weeks, but cost was high from USA. I have seen the TECHN recently which is based in Europe and looks very good and is reviewed here.
https://translate.google.com/translate?hl=&sl=de&tl=en&u=https://www.igorslab.de/techn-cpu-waterblock-gegen-watercool-heatkiller-und-ek-quantum-magnitude/&sandbox=1
Thanks I will have a look.
How much did the Optimus end up costing you?
Nope, I wonder if anybody from here installed it and what is their thought on this.
Ah I see.
Optimus Block cost £131.84 plus non sterling transaction £3.63 (used credit card) plus Import Taxes £30.43 total £165.90
If I had seen the TECHN prior I would have purchased that otherwise looks very good for around 100 Euro's I think. Beats EK Quantum Magnitude in the review and Egor well known for knowing his stuff.
That's a fair bit for a block, I was wondering if you were going to get hit with import tax.
Anyway how are you finding the block are you pleased with it? Is it worth the cash?
