recomend a psu for me
23 Jan 2005
hi son gave me his old rig and I have ended up renewing everything bar case and psu, and thought to do the psu first as its a few years old. So I have a ryzen 5 2600 with 16gb of the team 8 ram. 2x140 & 2x120 case fans and standard cpu cooler, 1 ssd & 1 sata hard drive and 1 dvd drive and a rx580 gpu, all running stock at the moment but that can change to a mild o\c.
So seasonic calc give the following
load 418w
recommended 468w
So I was thinking do I go for a 550 ish or 650 ish supply and which one ?
Thanks
Just finished a build using that PSU, and already have another running in the house - great quality and can also be set so that the fan stops when it's not required / under load.
Thanks all so I take it that even though Seasonic calc recommends 468w and allowing something extra 650 is recommended.
