- 6 Jan 2009
I need to buy a UPS for my PC, what do I need to know before selecting one?
The PC has a 750 watt power supply.
...most of the time it'll draw much less than that
But that's the maximum load that the PSU can safely supply not the load that the PSU itself draws. My computer has a 520W power supply but I only have a UPS rated at 500VA (approx. 300W) and it works fineYes, this is the case, but when the system shuts down it draws almost the full power that the PSU is rated at and if your UPS cannot supply it, your comp. will simply reboot making your under-powered UPS useless, so make sure you buy something which is spec'ed close to what your PSU is rated at...
(well apart from the fact that my battery is well past the recommended replacement date
)I only have a UPS rated at 500VA (approx. 300W) and it works fine
