Ideally you want a swiftech wth an Akasa Amber fan, but they're out of stock at the moment, so the Zalman 7700 is probably the next best if you want one immediately.
which one should i get not sure what will fit on mobo got a gigabyte 8s661fxmp-rz micro atx mobo didnt want to spend too much on a mobo as it came off a i875 board and when i upgrade to dual core ill be sticking a 3700 in small case with new mobo
