- 30 Jul 2007
I have
P182 -standard adjustable rpm fans
Abit Maximus Formula
T120 extreme cooler with Noctua NF-S12 ajustable rpm fans.
q6600
Ive bought my 'wet and dry' and going to lap the HSF and T120 using instructions on this forum.
I want to try and achieve a 3-3.6Ghz oc. Above 3Ghz I would like it to be as quiet as possible..
Can any one recommend a good starting point for the Fan speed configurations..or is there no substitute for just seeing what works.
presumably a high cooler fan speed is better than high case fan for CPU cooling and noise?
thanks
q6600
thanks
