Recomended Rebuild
9 May 2012
South Wales
Good Afternoon all
I'm just fought i'd see what people can recommend as a full rebuild custom pc, I will have about £700 maybe bit more. I know its not a lot in upgrade terms, but if its possible i woul like too.
I would be most gratefull if a few a you can recommend spec parts and prices plus your reasons for doing this ?
current build :
  • amd bull dozer fx 6100 3.3ghz black edition
  • asrock n68 vs3 motherboard
  • 8gb hyper x red 1066ddr3 ram
  • 500gb hard drive
  • 2gb ddr5 zotac 450 graph card
  • acer 750w red psu
  • 2 x corsair 120w led fans
thank you very much guys
thanks mark
500gb hard drive
Just an example - and slightly over budget but would run anything at 1080p.
I would use your current HDD and plug it into the below build.
I've included a small SSD for the OS, APPs and a few of your most played games - the rest would go on your conventional HDD.
The PSU is not the best - but it's better than your old PSU:
My basket at Overclockers UK:
Total: £749.19
(includes shipping: £12.30)
EDIT you get DOW 3 free with the Asus 1060 too.
Also assumed you're running a 64 bit OS - and ideally windows 10.​
