Recommanded PCI-E Freq.
29 Apr 2003
London, Forest Gate
I am new to overlocking - pls help me with these questions.
Question 1
What should be the recommanded (safe) PCI-E x16 freq
(What are the benefits ?)
Question 2
What is the default PCI-E x16 freq. ?
E6600 cpu
GIGABYTE S3 Mobo
1gbx4 GEIL 6400 (800ghz) 4-4-4-12
GFX CARD BFG 8800 OC2 GTX
pc running stable at 3.2ghz (pime95)
voltage 1.45
fsb 400
multiplier x8
ddr2 0.3v
Able to reach 3.6ghz (under different settings x9 / v1.525) easily runs windows for hours (but not stable under prime95) temps below 52c (load)
I've come across recommendations to lock it at anything from 100-120MHz, with claims that higher will give slight improvements in performance. In the end I've just settled on 105MHz and all seems good...
I keep mine at 105mhz. It helps the northbridge.
And anything over 115mhz severely increases the chances of hard drive corruption and even a dead graphics card.
Does it actually aid the NB in any way or was that just myth?
And whats the PCI-E bus got to do with HDDs?
Yep, I screwed up my windows install by leaving the frequency on auto :(
It's not a magic setting, but it does help squeeze the last few mhz out of the FSB and memory.
And PCI-E freq locks were introduced to motherboards to aid stopping the hard drive corruption that was being caused by raising the FSB in older boards.
Surely you mean the PCI freq
El Jimben said:
Nope because the PCI frequency is derived from the PCI-E frequency i.e. it's a third of it.
So was PCI-E developed before PCI? Yet only used recently?
(Im not being argumentative btw, im just interested! :) )
Before PCI-E, I assume that the PCI frequency came from the AGP frequency i.e. 33MHz and 66MHz?
AGP also came after PCI. This does not mean PCI-E frequency cannot determine the PCI frequency as the bios is not as old as PCI.
i would assume it WAS originally pci frequency, then agp can along, and it was then agp frequency, now pci-e is here, it's called pci-e frequency...
On my motherboard there is two PCIe frequencies. One says Northbridge PCIe 16x freq and this is at 125MHz. The other says Southbridge PCIe 16x freq and this is at 100MHz. Is this something to do with the fact the motherboard is SLI? It's a 680i board which has 3 PCI-E 16x (the one for physics runs at 8x though)
120mhz here.
EVGA 680i boards until recently had the PCI-E set at 125 (linkboost technology) but this was then disabled in future bios updates, no reason was given as to why.
I've always had my PCI-E speed at 100MHz, not seen or read any good reason why it should be higher except some people got a 'slight' boost to their 3DMark scores.
Somebody should do a comparison so we can see the benefit.
I'm not sure how the PCI-E bus affects hard drives? I know that if you don't lock the PCI bus to 33MHz you can loose your disks etc but not PCI-E?
I have my pci-e freq on my DS3P set at 100 but i dont seem to have a pci freq option, checked every option on every screen.
Can someone enlighten me or is there just no option to set pci freq to 33 on this board??
Ta.
Hmm, just tried upping it to 110 and the 3dmark05 score is lower than before (although its been a few weeks since i ran the one at 100). Nothing else has changed though:
PCI-E 100 17546
PCI-E 110 17442
Edit: PCI-E 115 17606
So read into that what you will :confused:
