Recommend 92mm cooler
12 May 2011
Southampton
I have a project PC with a 4790S 65w CPU in a mini ITX case and am using an Asaka top down heatsink which is reasonably chunky like Pentium 4 sized heatsink but it is hotter than I’d like and loud. Can some one recommend a 92m tower cooler that works with 1150 and is also high quality I.e. no push pins.
92mm fan on a tower. The cpu cooler clearance is apparently 140mm (Thermaltake Core V1) but my 120mm fan heat sink doesn’t fit. If there are compact 120mm fan solutions say 130mm then that’s fine but I doubt that leaves much room for ram clearance etc
