A couple of months ago I sold my sli rig, got myself a 360 and HDTV. Was just spending too much on upgrading every 6 months...no control whatsoever. Anyway, at work I just got handed a PC for some Beta 2 Vista testing (to do at home), but the video card on it is pretty much crap for gaming (x600 256meg Hypermemory).
The rest of spec is pretty good - P4 dual core presler (3.4ghz with 2 megs on each core), 2gig PC5300 DDR2, 500gig SATA, Xfi-Exteme. Motherboard is based on latest Intel chipset but is not sli or xfire compatible. Next month I would like to get a top gaming card though, and I will be running it on a 2 year old top of the line Sony 21" CRT, so it can handle resolutions of 1600x1200 and above. The PSU on this machine is only a 379w, but this system can support a 7800GTX 256meg (offered by manufacturer). So hopefully the ATI X1800/X1900 cards will also run ok. In any event the PSU is replaceable with a more powerful one as the case takes standard atx.
My question is this :
1. Is the 3.4 presler good enough to justify a 1900XT ? Or will I be severely cpu limited.
2. If the PSU can support a 7800GTX 256, do you reckon it can handle a 1900XT. Bear in mind there will be the cpu (not overclocked), 2gig ram, 1 HDD, 1 Optical, Card Reader, TV Tuner card and Soundcard running.
thanks
thanks
