Recommend a case £80-120
Well the HAF is definitely ugly, but how is the airflow and noise compared to the Antec 1200 and also the 900 which is quite a bit cheaper.
Antec 1200 all the way, its more of an investment id say aswell as it will server quite well for future upgrades as it has premium thermal dissapating properties.
Received the Antec 1200 today, everything installed, only problems I can see are my PSU's cables are not long enough to go round the back of the mobo so they block me installing a side fan, theres not enough room behind the mobo and side panel as I'd like.
Needs more light, i'd install my own but theres nowhere to put them, so I now need a new PSU, which needs to be modular and have cables long enough to go round the back and also some decent 120mm fans with blue lights to match.
Cooling is great though and I really like the build quality, solid case.
Will be powering Q9550 with P5Q-E, and GTX280, all overclocked.
Wouldnt bother getting new fans unless you your actually worried about the fan noise of the antec fans. Just get a cold cathode or 2 and light up your case.
But theres nowhere to put them unless you want one directly in view in the side window which I don't want.
The fan noise is fine on lowest.
