Recommend a case for 280mm AIO and 360mm AIO
31 Dec 2007
The TARDIS, Wakefield, UK
I have the Arctic Cooling 280mm AIO it has a thick radiator and I was intending adding a 360mm Radiator AIO for the GPU.
So basically can anyone recommend a case that will fit both in either top/front combination ? I was thinking about the Meshify 2 but
they list the it as OR suggesting you can put but a 280mm in the front and a 360mm in the top at the same time.
Also could do with plenty of clearance between the top of the motherboard and the top of the case as if I stick a 280mm AC one there
they are quite thick and I had to move one of the fans in my cheapo Xigmatek case to the outside to get it to fit.
I`m actively looking/searching through case specs for one now but just wondered if anyone already had this combo whether with AIO or
full watercool.
