21 Aug 2012 at 21:12 #1 nitram100 nitram100 Soldato Joined 7 Aug 2009 Posts 4,965 Location London Hey guys, I have about 60 quid for a case and have 4 requirements Removable HDD cage, Top mounted 120mm fan (preferably 2 but 1 would be ok) USB 3.0 sockets on the front Ability to mount an SSD. Any recommendations? Thanks!
21 Aug 2012 at 21:28 #2 MonsterMoshi MonsterMoshi Associate Joined 16 May 2011 Posts 1,308 Location Staffordshire Style? Minimalist? Aggressive looking? Do you need any 3.5" bays or just 2.5"? ATX I presume?
21 Aug 2012 at 21:29 #3 nitram100 nitram100 Soldato OP Joined 7 Aug 2009 Posts 4,965 Location London Not really bothered about style to be honest, having a hard time finding a case with removable HDD as it is so not going to be picky on design!
21 Aug 2012 at 21:34 #4 MonsterMoshi MonsterMoshi Associate Joined 16 May 2011 Posts 1,308 Location Staffordshire BitFenix Raider BitFenix Survivor Fractal Core 3000 (no USB 3.0 although you can mount some in the front expansion bays) Xigmatek Midgard II Some options there for you Last edited: 21 Aug 2012
21 Aug 2012 at 21:37 #5 unclelonghair unclelonghair Associate Joined 29 Sep 2004 Posts 906 Location Newcastle upon Tyne If you can stretch your budget a little bit the Corsair Carbide 500R fits the bill.
21 Aug 2012 at 22:09 #6 nitram100 nitram100 Soldato OP Joined 7 Aug 2009 Posts 4,965 Location London Thanks a lot guys! That midgard II fits the bill perfectly
