Recommend a case
9 Jan 2010
S yorks
I'm building a PC for my brother to introduce him to PC gaming but my idea to use an ITX system is not going to happen because the GPU I bought him is wider than dual slot.
I am after something small so preferably M ATX, something quiet is essential and it needs to hold the following kit I have already bought him:
2600k
Corsair H100
1 SSD
1 3.5" storage drive
Graphics card 65mm wide (GTX 680 with aftermarket cooler)
Standard PSU
I still need to buy him a mobo, power supply and the drives
Bitfenix phenom or prodigy, both the itx and matx are the same size so not sure if the itx version of that will be ok for your needs along with a itx z77 mobo.
The colossus m was my original idea but the GPU is too wide for the ITX version and I rang overclockers customer support this morning and the M ATX version won't fit the h100 in with a graphics card!
I ordered a Dead Silence in white and black! the fact its quiter and looks better tipped the balance. thanks for the advice!
but how do you add the parts to posts?
