Recommend a CD/DVD Burning Program
20 Sep 2003
Scotland
Hi
I am looking to buy a decent piece of CD/DVD burning software. I will be using it to burn multiple file types to CD and DVD. In the past I have used Stomp RecordNow Max v4.5 and really liked its simplicity and layout but time has come to move on and upgrade. I have tried the latest offering from Stomp but find them just too bloated and messy, I find the same with Nero as well. Ideally if anyone knows of any free programs that fit the requirements, that would be great.
Thanks.
Recently used the new Nero burning suite software and thought it was exceptionally good for making movies and recording any types of data and would heartily recomend it.
At the moment I use CD Burner Xp Pro which is free and always seems to be able to do what I need of it,
IMGTOOLBURN is supposed to be quite good (if you the ISO already created) and just need to burn it off. Apparently Nero isn't so good on DVD-Videos. Don't ask me why.. :confused: Something on RPC-1 forums.
