Recommend a cooler for AMD 6350
14 Dec 2003
Lincs
Hi, my son has an AMD 6350 and is using the stock cooler, could anyone recommend a decent'ish cooler (around £30) that uses the (AM3) standard method for installing.
He doesn't overclock at all, just would like something quieter that I can quickly install with a minimum of fuss.
Thanks,
Bear in mind these coolers require you use the (included) backplate, I don't know the best non-backplate cooler but the freezer 7 pro is a pretty good one.
