Recommend a cooler for P400a & 10600K
22 Feb 2010
So I ordered a NZXT Kraken z63 for my new build and I chickened out after reading a lot of bad reviews of the unavoidable CAM software and refused the delivery.
Can anyone recommend and air cooler for this build?
Case has maximum cpu cooler height of 160 mm the Arcti e 34 sport is a good £30 option, duo £35
Scythe smng 5100 mugen 5 rev b.
why not a different AIO if thats the route you want to go down?
I wanted the cash burn bling of the LCD display... Then on closer inspection of the case specs I realised it can't take the rad in the top and then I'd lose the 3 RGB fans in the front.... and on and on etc. So decided to go air for simplicity.
I'd fit a 360 at the front then. **** RGB
