I'm planning to build a TV Cabinet Gaming PC.
I plan to use this case or similar
http://www.overclockers.co.uk/showproduct.php?prodid=CA-112-SV
I will probably go with an i5 Haswell 4690 or 4690K (I don't plan to overclock but may go with the K version anyway) (85W).
I will probably go with a GTX960 (120W).
The case supports limited height coolers
70mm if I fit an optical drive
120mm if I don't fit an optical drive
I would also be using a mATX and I'm not sure whether the smaller MoBo also limits what coolers will fit.
My past builds have all been in tower cases with oodles of space so I have just thrown in something overkill.
But I'm not sure what would be best in this case. Would appreciate some recommendations both within the 70mm and 120mm limits as I haven't for or against the optical drive.
Cheers,
Nigel
Cheers,
Nigel
