Recommend a few benchmarking progs for me?
22 Oct 2008
Lisburn
I'm moving GPU and I would like to run some benches on my old card and then slot the new card in and run the same. To see what the performance gain is. Can you recommend some FREE bits of software that I can run to give me the comparison I want?
I'm moving from MSI gaming 280x to a XFX 7990
3dMark
3dMark Vantage
3dMark 11
Uniengine Heaven
Uniengine Valley
surprised you didnt work that out from the threads on here :)
To be honest I don't really do bench marking. As long as the card plays the games I play I just play them. I have Valley already so I'll download the others and use them as benches. Any specific settings I should use or just do default settings?
A lot of the benches listed above will have settings stipulated in the opening post. Use theese to give you something to compare to other users with similar setups.
