Hi all,
Not new here but haven't been into computers in a long while.
Can anyone recommend me a slim ATX case capable of a custom loop watercooling? (smaller/slimmer the better)
Though the case has been discontinued, shouldn't be hard looking for one to buy, i do have my eyes on the Thermaltake Core G3. Not sure if there are others of similar capability.
Note - Anyone who has a G3, how much clearance is there left if you were to have a GTX2080Ti propped either vertically or horizontally
I would have gone for a smaller form factor than ATX, but i'll be reusing my current PC setup into the new case which will be targetted for VR use, and my main PC config will be new parts in my current Corsair 750D.
Current PC parts include:
Asus Maximus Z87 Formula VI mobo
Intel 4770K
32Gb Corsair Vengeance Memory
(new) nVidia GTX2080Ti GPU (when the 3000 series release)
(new) SFX 700w PSU
Watercooling would include:
(new) EKWB 240 Slim radiator
EKWB Intel CPU Waterblock
(new) EKWB GPU Block
(new) EKWB DDC Pump/res combo
couple of Noiseblockers 120mm fans
Tubing pending on case size
I know the case i have my eye on is too small for a push pull config, but the system will have light overclocks and cooling performance doesn't have to be a major factor. I have also had a look at the NZXT H510 series and think that is still quite big, so smaller than that or even slimmer would be perfect.
Budget - Less than £150 sounds reasonable
Many thanks
Intel 4770K
(new) SFX 700w PSU
Many thanks
