Recommend a system for £500 to £600
19 Nov 2015
Hi danny thanks for that
It didnt show any other images just the 3 case
What do you think about the system. Or is there a better rig
My basket at Overclockers UK:
  • 1 x "ForceBox Gamer Plus" Intel Core i5 4690 3.5GHz (3.9GHz Turbo) Quad Core Nvidia GTX Special Edition = £667.94
    • Case:BitFenix Phenom MATX Cube Case - Nvidia Edition - White
    • Memory:TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLYED38G1600HC9DC01)
    • Graphics Card:MSI GeForce GTX 750Ti OC 2048MB GDDR5 PCI-Express Graphics Card (N750Ti-2GD5/OCV1)
    • Primary Hard Drive / Solid State Drive:Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU)
    • Secondary Hard Drive / Solid State Drive:No Second Hard Drive Option (ZERO Cost)
    • Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
    • Security Software:Unwanted
    • Warranty:OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour)
    • Build Time:Standard Build Systems - Dispatched within 7 working days
Total: £682.04
(includes shipping: £14.10)
You're welcome.
The Forcebox Gamer Plus spec you've selected has a nicer case (at £69.95 it's on the expensive side for this total budget), and a 200MHz faster CPU (this will hardly make a difference for gaming). However, the 960 4GB is a considerably better GPU than the 750Ti so the gaming performance of the spec with the 960 is superior. There's also the AMD 380 4GB for £10 extra, which is a little better than the 960 overall. But given your preferred case choice, I think you favour Nvidia.
For GTA V you do want more than 2GB Vram if possible. It does use more, easily. You'd have to cut down on several key graphics settings for that game to get it down to around 2GB.
My spec plus OcUK build fee should come out cheaper than £682.04.
My opinion is that the BitFenix Phenom Nvidia White is pricey for the budget and cuts into the performance (don't go with the 750Ti). So I would advise you to look for a cheaper case that you like, unless you really like the Nvidia Phenom case and don't mind spending extra for something like this:
Total: £658.18
(includes shipping: £12.30)
My rough guess (OcUK decides the quote for each build) is that the total for the above could be £700-720.
The Asus H81M-PLUS motherboard is a slightly better option than the H81M-K (the latter lacks USB 3.0 for case headers).
Total: £615.62
(includes shipping: £11.70)
or pay extra and get a K i5
on another note, i have the asus H81M-Plus and its a great board, but i have a locked i3 so i dont know how good the overclocking is as i cant check, but the bios menu is the best ive ever see, so nice to look at and good information/options.
Total: £615.62
Spec doesnt fit, GFX card too wide for the case ;)
