Recommend a USB power bank 40000mah-50000mah?
At that capacity, aren't they all fakes?
That must be around 200Wh, so not allowed on flights.
Seems I may have written the first sentence in haste, because after searching there are some 50Ah ones (sorry 50,000mAh since bigger numbers look better). No idea about quality though.
Up to 300Wh is allowed on flights which is 83Ah.
All talk about flights here but OP never mentioned what it was needed for.
If it is for flights, check with the airline as to what can be taken onboard rather than advice from a forum.
