Recommend an ISP
Don
7 Aug 2003
Aberdeenshire
Had been looking at Be but they're not available at my local exchange.
I'm looking for someone that will let me turn off interleaving without much hassle + static IP I'm not a big downloader but any cap would need to be 20GB+ a month if not unlimited.
Any non-LLU recomendations?
Non-LLU means BT resold. So getting interleaving or anything else done on the line will be more hassle than it should be purely because BT won't deal with you direct, you have to go through your ISP which introduces the widely denounced man in the middle scenario.
I've not seen many BT resellers that will offer a Static IP on a home package, some might with additional charge though. Probably something in the region of £4 -5 per month.
My advice would be if you can't get decent LLU service then go cable if you can.
Treat BT resale as a last resort.
Hmmm, looking at Samknows seems I can gett LLU from Sky (don't want their package) or Orange. Any idea if Orange are any good or to be avoided (I'm guessing the second)?
Excellent, I'll have a look into them.
Edit: Their speed check is saying I could get 16MB \o/
Edit: Of course they might just be saying that to get me on their highest tariff :p
I am with http://www.ukfsn.org/ they are an Entanet reseller and I have had nothing but good experiences with them, English call centres etc. They are also very clear on usage limits and do not throttle if you go over, instead just charge you for the extra GB's
