Recommend box sets
24
Battlestar. Galactica
24 is probably my most fav tv show of all time...phenomenal depth to it...rewards rewatching
Thanks again guys, job done, picked these all up on a well known auction site super cheap.
Dexter S1
Fringe S1
The wire S1
Justified S1
The shield S1
I wanted Into the west but its only on import and a bit steep
Good Wife (don't be put off by the name)
Suits
The Wire
Walking Dead
Justified
The Shield
The Wire
Dexter (goes off towards the end imo)
True Detective
Hannibal
Suits
The Wire
Walking Dead
Justified
The Shield
The Wire
True Detective
Hannibal
Just picked up Good Wife for a fiver, thanks for the recommendation.
Cheers guys, I now have enough shows to do me the rest of the year!
Just one thing - am kicking myself slightly for not exploring it before - amazon prime actually does have a few good shows on it - have been subscribed for a while simply because I use it a lot for next day delivery but there are some classics on there
'freaks and geeks' is worth checking out - only lasted one season but was a very good show
Dexter S1
Fringe S1
The wire S1
Justified S1
The shield S1
Into the West can be had for less than £5 from the rainforest.
Yes! Very likely - tis a good series.
no good for the OP if he didn't like the Sopranos but if you like that gendre then definitely worth watching
