Recommend Case
4 Mar 2008
Hi,
Can anyone please recommend me a case as I want it to have a clear side window for viewing the internals and also use it for watercooling but I want to put the swiftech system in it. The cases I have looked at which have windows either have watercooling integrated or I'm not sure are big enough. I want to cool the cpu, vga and chipset also with the option of cooling a 2nd SLI graphics card.
Any help would be most appeciated. I had the Lian LI A70B in mind at first but it does not have a window to show internals. I'm a bit paranoid in my nature so I would want to keep a check easily on anything leaking with a watercooled setup.
Thanks,
Gray.
PS. I don't want to have to mod any case to fit the watercooling. I have a budget of around £150ish.
