I'm in a position where I can do a pretty good upgrade to Core 2 Duo on the cheap. I have :
- Pentium D 805 (Running at stock because my mobo cannot overclock to speak of.
- 2 * 1gb PNY DDR2 667 - Slowish timings at 2T command rate in dual channel but it is 667 speed.
- X1800XT - Currently running through a 4X PCI-E slot due to mobo limitation.
- AKASA Paxpower 400W.
My mobo does not support core 2 duo & as you can see, is generally limiting me a bit. I want to get a core 2 duo but need a motherboard to go with it. It's essential that it have memory dividers because I plan to overclock the C2D. I'm not looking to buy new RAM & my stuff is essentially value RAM, so I figured I would clock it down so it is clocked back up to stock speed as I raise the FSB.
I'm not upgrading my graphics card because I'm more than happy with the performance it provides but I would like to use it on a true PCI-E 16* slot.
So my question - what resaonably priced (£100 or less) mobo would you recommend ? AND, using cheap RAM like I am, would the e6400 be a better choice for CPU (6600 & above are not for consideration due to cost).
I don't want a super high clock, would be happy with 2.6 - 3.0 ghz but I don't want to have to fiddle too much to get it.
What mobo would you recommend & which CPU ? I've considered the Gigabyte DS3 / S3 but I think they don't have memory dividers - or am i out of date ? Also, the Asus P5B (Non-deluxe) but are there cold boot problems etc. There is also the DFI infinity 975 board but they have a reputation for needing a lot of tinkering, many settings & wanting expensive RAM. There's also some Foxconn 965 borad for about £80. Please feel free to suggest anything else too.
Thanks for your time.
