- 2 Jul 2004
- York
I need some advice please:-
I'm looking to connect 4x 42inch Plasma or LCD TV's (yes, I said 4
) to a single server class PC (8 gig ram, top spec PC).
The problem I have is I lack experience / knowledge of having done this before. Obvioulsy I'll need a few decent graphics cards to connect the screens to - this is where I need some help.
Can you please recommend the graphic(s) cards to use. Is it best to connect by DVI? One issue could be that 1 screen will need a 70m cable run to the server! Would this cause signal loss and can I get / make a DVI lead that long?
Any help you can offer would be greatly appreciated.
Budget isn't too much of an issue either
Thanks
Thanks
