Recommend Headphone PS5
Permabanned
2 Feb 2010
Haywards Heath
Can anybody recommend a good set of headphone for PlayStation 5 , not the Turtle Beach Stealth GEN2 700P as they are absolutely terrible , worse headphones Ive ever had . So many problems with loosing connection when playing, i have done updates and still have the same problems , so i will be getting rid
Thanks :D
HyperX Cloud Flight. Great audio with crisp highs and deep bass with a very good sound stage. Good clear mic and up to 30 hours battery life with the led off. Great comfort with soft leather like cups.
I was looking at the HyperX CF aswell but torn between buying them or waiting for the Pulse 3D to be back into stock, they are like rocking horse poop to get hold of.
Audeze Penrose, best wireless headset I've used. Not even in the same league as most other gaming ones.
Do you need a built-in mic etc..?
If not then I'd look at some of AKG's range. can spend as you did on the one in the OP but even stuff for less than half that price can be quite competitive - for example the K240s.
I think OCUK stocks some of the AKG range.
