recommend me a 22 wide please
24 Jun 2004
Carnoustie
looking for an upgrade on my philips 2006ws 20 inch wide
could anyone please spec me a new 22 inch was intrested in the Belinea 2225S1W 22" Widescreen LCD Monitor - Black/Silver or
Samsung SM-226BW 22" Widescreen LCD Monitor - Silver/Black
would either of these be an improvment thanks
I wouldn't call going from 20">22" an upgrade. Both sizes will use the same resolution so the image will just be stretched. There have been a number of people on here who have commented on the clarity of 22" screens as they are used to having a sharper image on a smaller screen.
Another thing to note is that the Philips uses a better panel type than the TN panels in the 22" screens. You would end up losing viewing angles and possibly colour quality. This wouldn't be such a problem for people moving from a TN panel to another TN panel but seeing ase you've used a higher quality panel you'd probably notice the difference.
To answer your question, i would go for the samsung over the belinea as it has dvi and 16.7m colours. However, i wouldn't look at it as an improvement.
thanks for your comments ,im now not sure :confused: i was kinda hopeing for an improvement all be it little ,now im lost would have liked a bigger screen ,not sure if its worth it now ,anymore advice ;)
I would stick with what you have at the moment and wait and see what happens in the 22" market. More panel types may start appearing for that size. If not then the only other upgrade would be to go for a 24" screen or maybe even larger ;)
