Recommend me a 570?
True, is there a difference between that and the most expensive one, cos If i overclock the cheapest one, wont it run on par with a gtx 580
The only differences are the coolers and the factor overclock, with the cheapest card, you're still going to be able to reach the speeds of the fastest factory over locked cards with ease, no guarantee you can clock it as fast as a 580 though
