Recommend me a 780gtx?
Hi all.
do i need a new PSU to power this beast?
Review: EVGA GeForce GTX 780 Classified - Graphics - HEXUS.net - Page 12
It says it draws more power then a titan!
Currently i have a i7 920 clocked at 3.8ghz, 6gb ddr ram, 3-4 sata hdd and one SSD plus 5-6 case fans all powered by a corsair gold 800w PSU.
Thoughts?
If your running stock bios and don't heavily overvolt the card you should be fine.
There are bios available for the Titan and LLC and afterburner voltage hacks available that allow the Titan to draw 500w, I believe the mods also work for the 780 ;)
Hi all.
Thoughts?
I run a heavy overclock on the CPU, watercooling pump, 2 HDDs, 2 SSDs and the same Classified card (which is also overclocked) on a 750 Watt Corsair PSU.
Not had an issue in the 5 weeks ive had it, although i did have the same concerns :)
