- 10 Oct 2012
Hi all,
Long time lurker needing some help if possible.
I bought my last bundle from OcUK back in 2010 and it has been serving my needs very well, however I'm getting the itch to upgrade (it's been a very long 3 years..).
I'm currently running this system: *OVERCLOCKED* Intel Core i5 750 2.66Ghz @ 4.00GHz / Gigabyte GA-P55-UD5 Intel P55 Motherboard / Corsair XMS3 4GB (2x2GB) PC3-12800C9 1600MHz DDR3 Bundle and apart from the odd stutter now and then it's been brilliant.
I'm not after the biggest and best bundle (400-450 is my budget) but I'm looking for something that will give me a bit more oomph.
If I could get more value out of buying separate components then I'm also happy to do that and build my own, however I'm not too comfortable with the idea of doing my own overclocking after my previous attempts back in 2002 resulted in the death of an AMD XP1800(!).
Thanks in advance
Thanks in advance
