recommend me a cable\ADSL router please.
hi Tolien,
Can you explain what you mean please? Sorry but i,m not very teccy ...let me explain what i am after if it exists!
I am moving flat for a couple of months that has cable installed but then am moving back to an ADSL wired flat.
What i want is something that will allow me to set up a wireless network for both ADSL and cable. The cable company provide a cable modem but i want to attach more than one pc... Is this possible please?
thanks
ferret
The ethernet ADSL modem would take the place of the cable modem, and the router's just any router you'd use for cable. When you change to ADSL, just swap the modems (configuring the ADSL modem might be a good idea too, but that goes without saying).
thanks tolien but i,m still a little confused??!
I currently have a US robotics 9105 ADSL modem\4 port router which is not wireless...so can i use this to route a cable connection in my new flat?
i.e. can i plug the cable modem into the USR9105 which would allow me to connect up two pc's via cat5 cable?
If this works then i wont need to buy a wireless cable router.
Thanks
ferret
No.
