- 10 Jun 2010
- Scotland
I'm looking for a camcorder. It's main use will be filming badminton, a very fast sport where the shuttle itself can reach over 200mph. So I'm thinking fast shutter speeds, high frames type thing.... wait... shutter speeds? That's cameras right? anyway!
Budget... under a grand. As much or as little below it as needed.
I may do a little editing of the videos, however it will mostly be playing back and analysing. Slow motion would be a good thing, to analyse body movement, position and execution of shots etc.
It will be used on a tripod.
On the other hand. I'd like to use it to film other things when I go days out or travel or whatever.
I have a very limited knowledge of camcorders unfortunately. Is flash memory the way to go?
Cheers!
Cheers!
