Recommend me a closed loop cpu cooler
22 Feb 2015
I'm finding it hard to know what is currently considered the best closed loop cpu cooler.
Seems like the h100i gtx or h110 gt
By corsair.
Or nepton 240m or nepton 280xl
Does anyone know what is the best to go for?
I know in terms of air noctua nh d15 is the best, but finding it hard to figure out in terms of aio water.
I'm sounding like a stuck record here, but I have been nothing but highly impressed with my recent purchase of a Raijintek Triton Core. Slapped a couple of case fans on it and the performance has been outstanding.
The pump is totally quiet at 3000RPM, temps are 20+ to 30+ at idle (usual difference in temps between cores) and never goes above 55C in normal use.
There were reports of a few of the first versions leaking, but Raijintek are on version 2 or 3 now, and hopefully any teething problems have been sorted.
A doddle to fit, and I think it looks great, with its LED lit built in mini-reservoir.
